Image: Acer
Acer has spec bumps and display upgrades for its top-of-the-line Predator Helios 18 and 16 gaming laptops coming later this year.
Announced at CES, the Predator Helios 18 AI gaming laptop now sports a dual-mode Mini LED display that can switch between 4K with a 120Hz refresh rate or 240Hz when running at 1080p. That maximum refresh rate is actually a smidge slower than its 250Hz WQXGA Mini LED (2560 x 1600) predecessor, but that might be worth it for folks who want to enjoy both 4K resolution gaming and high frame rates on a single device. The Predator Helios 18 AI can reach up to 1,000 nits of brightness and supports Nvidia G-Sync to help prevent screen tearing, display stutter, and input lag.
The design for the new Predator Helios 18 AI gaming laptop has also been updated to display more configurable RGB lighting.
The internal specs have also been upgraded, with configurations offering up to an Intel 15th Gen Core Ultra 9 275HX processor, Nvidia GeForce RTX 5090 mobile graphics, 192GB of DDR5 system memory, and 6TB of PCIe Gen 5 SSD storage. The RTX 5090 GPU, in particular, is at least partially responsible for the “AI” inclusion in the laptop’s updated name, which supports over 150 optimized AI apps for things like LLMs, image generation, and more, according to Acer. The Predator Helios 18 AI will be available in the US in May, with pricing starting at $2,999.99.
Aside from size, the Predator Helios 16 AI is nearly identical visually to its larger counterpart.
The Predator Helios 16 AI has also received some generational improvements, including a 2560 x 1600 OLED display with a 240Hz refresh rate. It can be configured with the same processor and GPU as its larger counterpart, alongside up to 64GB of RAM and 4TB of PCIe Gen 5 SSD storage. It’ll hit shelves in the US in June, with prices starting at $2,299.99.
Both models also feature swappable mechanical keys and proprietary sixth-gen AeroBlade metal fans for thermals, which Acer says can increase airflow by up to 20 percent compared to plastic fans. While both models include support for Wi-Fi 7 and Bluetooth 5.3, port selection is now limited to two Thunderbolt 5 jacks — which might be restrictive depending on your existing peripherals and gaming accessories.
