If you’re a laptop worker who often feels restricted by a single laptop screen, you can boost your productivity with a portable monitor. That’s right, you can have a dual-screen setup while on the go!
And right now, this gorgeous Asus ZenScreen is on sale for $169 on Amazon, a nice 26 percent discount off its original $229 MSRP.
The Asus ZenScreen is a super-slim 15.6-inch IPS monitor with a 1920×1080 resolution and its own foldable smart case. When you aren’t using the case to prop up the display, it’ll keep the screen protected against scratches. (And the case can fold in both orientations, so you can prop the display up either vertically or horizontally!)
You won’t need any complicated cables to connect this one to your laptop, as it features both USB-C and USB-A connections. The monitor gets both power and video transmission through the same cable.
Other notable features include an anti-glare display, flicker-free technology, auto-sensing of rotation and orientation, and a complementary 3-month subscription to Adobe Creative Cloud.
If you’re often working on the go and simply can’t do without a second screen, get this Asus ZenScreen for $169 on Amazon and unleash the portable productivity you’ve always needed.
Get this 15.6-inch portable monitor for 26% off
Buy now on Amazon
Buy now on Amazon
