Upgrading your living room, gaming room, or even bedroom can be as simple as adding a couple Govee smart light bars to the back of your TV or monitor—and now you can do so at a discount because they’re down to $35 on Amazon when normally they’d be $50.
Usually available for $50, these light bars will help you set the right vibe for what you’re playing or what you’re watching.
These smart LED light bars look gorgeous and they’re so versatile because you can use them in their stands (either horizontally or vertically) or you can attach them to the backs of TVs and monitors.
The Govee Smart LED Light Bars can also sync to your music with their built-in high-sensitivity microphones, so that they pulse to the rhythm of songs, movies, or even the games you play.
Of course, you can also choose one of the many dynamic presets available through Govee’s app, or you can personalize them however you want through the DIY mode. These light bars help to create an immersive sound and light experience, transforming your fun nights.
Even better, Govee’s light bars are compatible with voice control features via Alexa or Google Assistant for hands-free operation. You can adjust the various settings (e.g., brightness, colors, lighting effects) with your voice.
Now that these Govee Smart LED Light Bars are 30% off on Amazon, there’s never been a better time to RGB-ify your home.
Get these Govee light bars for just $35
Buy now on Amazon
Buy now on Amazon
