  • " /> News - eufy launches the world’s first robot vacuum with a portable deep cleaner (plus other powerful model) | SoftoolStore.de - Программное обеспечение, Avid Media Composer, Книги, Новости, Windows, Интернет-новости, Бесплатные прокси (HTTP, Socks 4, Socks 5)
    News eufy launches the world’s first robot vacuum with a portable deep cleaner (plus other powerful model)
    Are you ready to completely overhaul your floor cleaning routines? The eufy E28 and E25 have just landed, and we bet you’re going to want one of these robotic cleaners delivered to your home sooner rather than later. Under pre-sale now, be sure to order and save your spot in line with these powerful units.
    The E25 and E28 are two brand-new models unveiled by the company. Both feature eufy’s award-winning HydroJet mopping technology and deliver a jaw-dropping 20,000Pa suction power for a deep clean.
    Deep-clean stained carpets, stairs and sofas
    The E28 isn’t like other robotic vacuum cleaners with mopping capabilities and a self-cleaning base: this is the world’s first robotic cleaning system to feature a detachable portable deep cleaner that can handle carpet stains, and clean stairs and sofas. It’s an all-in-one cleaning solution that–if you have kids or pets–your house will thank you for.
    Pre-order Eufy E28
    eufy
    eufy’s patented FlexiOne technology allows a detachable motor to power various elements of the E28. This makes it possible for the base station water tank to be removed and used as a portable deep cleaner for furniture, stairs, carpets, and pretty much anything else that needs a deep clean, including your car seats.
    You simply disconnect the water tank, carry it to the spot that needs cleaning, unwind the hose, and just clean whatever spot needs attention. The eufy E28 could potentially save you big bucks that you might otherwise have to spend on an upholstery cleaner, not to mention the space you’ll save for storage.
    It’s this portable deep-cleaning function that separates the E28 and E25. Both are powerful, all-in-one robotic vacuum and mop systems–but if you don’t have a need for a portable deep cleaner (perhaps your home is all hard flooring), the E25 is one of the most powerful robotic vacuum and mopping systems on its own.
    Pre-order Eufy E25
    eufy
    Powerful cleaning in any scenario
    With 20,000Pa Turbo suction, the new eufy robots can lift dust, pet hair, food crumbs, and whatever else is on your floors, carpets, or rugs. Using DuoSpiral brushes, which prevent hair from becoming entangled (a frustrating problem with many alternatives), these robot cleaners make quick work of your floors.
    The eufy E25 and E28 also feature an extending CornerRover arm that can reach into tight corners and edges, making sure all areas are thoroughly vacuumed.
    When it comes to mopping, the eufy E25 and E28 take things up a notch. Instead of relying on a moving pad or rotating round mops, these robot vacuums have a rolling mop. The HydroJet system ensures the rolling mop is continuously washed as it moves over your floors, scraping away dirty water and replenishing the roller with clean water and cleaning solution. The rolling mop doesn’t just glide over the floors, it applies 1.5kg (over 3 pounds!) of downward pressure–your floors will be as clean as if you had hand-scrubbed them.
    Hassle-free maintenance and operation
    eufy includes an Omni docking station that does all the maintenance work for you. The robot self-empties when it returns to the base, and the station then washes the mop, dries it with hot air, automatically adds detergent, collects the waste water, and refills the robot’s water tank.
    You can also pair the eufy E25 and E28 with Alexa, Siri, or Google Home, which will allow you to control the robot with your voice.
    Where to buy eufy E25 and E28
    Both the eufy E28 and E25 are available for pre-sale at eufy’s website. The E28 is available for $1,299, while the E25 is $999. eufy’s E28 will be available from April 23, while the E25 is scheduled to arrive in June.
    Pre-order Eufy E25 & E28
