Having a power bank in your bag is the smart thing to do because you don’t want to end up with a dead battery on your phone, especially when it will be a while before you reach home.
Thankfully, Anker’s super cute Zolo power bank is only $14.48 at Amazon right now. Since you can normally get it for $26, that’s an amazing discount. You do have to remember to add that extra 10% off coupon to get the price we mentioned above. Otherwise, it’s “just” a 38% discount.
This is a 10,000mAh power bank, which means you can get about two full recharges out of it, depending on your smartphone’s battery. It’s not fit to recharge laptops, but it will do just fine with phones, tablets, and other smaller gadgets.
With a maximum of 30W charging, this is a great pick for both Android and iPhone users. There’s a built-in USB-C cable that makes it super convenient to use this one over other models because you don’t need to worry about getting any other cables.
There’s also an additional USB-C port on the top and a USB-A port on the side, so you can charge multiple devices at once if you need it. The digital display will tell you how much battery you have left.
For $14,48 at Amazon, this is an absolute bargain for the Anker Zolo power bank and you should add it to your cart sooner rather than later.
Get a power bank with a built-in cable
Buy now at Amazon
Buy now at Amazon
