Over the years, motherboard manufacturers have consistently pushed the limits on top-end motherboards with striking designs and PCBs filled to the brim with the latest controllers and feature sets. Although these typically come with a high price premium, these 'flagships' represent the latest components, designed to operate the fastest processors to deliver leading-edge performance while offering the best controllers available at the time of manufacture.
One such model is the GIGABYTE Z790 Aorus Xtreme, which is the direct successor to the Z690 Aorus Xtreme, and boasts a premium feature set, including support for DDR5-8000 memory, dual Thunderbolt 4 Type-C, as well as 10 GbE and Wi-Fi 6E connectivity. Sitting at the top of GIGABYTE's Z790 range of motherboards, the Z790 Aorus Xtreme is designed for Intel's 13th (and 12th) generation Core series processors, and as such, benefits from advancements such as PCIe 5.0, native USB 3.2 G2x2 connectivity through a front panel header, and 10 x USB 3.2 G2 Type-A ports directly located on the back panel.
In a market with a massive choice of motherboards, the GIGABYTE Z790 Aorus Xtreme has plenty of bells and whistles and appeals to users looking for the best motherboard designs and technology. Despite not being cheap, GIGABYTE, over the last couple of generations on both AMD and Intel chipsets, has offered good levels of value while offering solid performance levels. Today we're taking a closer look at the Z790 Aorus Xtreme to see how it stacks up against other LGA1700 motherboards with our Intel Core i9-13900K and if there's any value to be had amid the solid and premium feature set offered by GIGABYTE.
