  • " /> News - Project Arielle is Razer's first temperature-controlled gaming chair | SoftoolStore.de - Программное обеспечение, Avid Media Composer, Книги, Новости, Windows, Интернет-новости, Бесплатные прокси (HTTP, Socks 4, Socks 5)
    News Project Arielle is Razer's first temperature-controlled gaming chair
    How are you ever going to improve your Elo if you can’t stop shivering or sweating in your gaming seat? Razer’s latest deskside innovation is Project Arielle, a mesh gaming chair with integrated temperature controls — and some pretty lights, of course.
    Project Arielle is built on the foundation of the Fujin Pro, Razer’s breathable mesh chair, and it uses a bladeless fan system to warm up or cool down the entire frame. A touchscreen panel on the side of the seat offers three fan-speed settings, and lets you swap between cool and warm airflow. The edges of the seat and backrest are lined in a thin ribbon of RGB lights, and these dynamically shift between blue and red as the set temperature changes. The bladeless fan is housed in a cylinder dangling off the base of the backrest like a little stubby tail, and a cable runs from this same area, connected to a sizable power brick.
    Razer says Project Arielle can reduce the perceived temperature by 2 to 5 degrees C in dry environments, and its self-regulating, energy-efficient heater delivers warm air of up to 30 degrees C (86 degrees F).
    Razer
    In action, Project Arielle is surprisingly effective and quiet. I had a chance to experience — not just sit in — the chair at CES 2025, and it functioned even better than expected. With the warm setting engaged, I felt a breeze of heated air swirl around my head, neck and upper back, and the temperature change was tangible even in a hot room. The cool setting provided instant relief, with the airflow particularly noticeable along my back, neck and under my arms. The fan was noiseless in the demo room, which contained about a dozen people and a handful of laptops and PCs. I strained to hear the fan running in this environment, and even then, it was barely noticeable as a soft hum.
    As someone who’s always chilly, especially in sedentary situations, Project Arielle is an incredibly attractive chair. Instead of piling on sweatshirts and blankets to warm up my frozen bones, I’d be happy to just switch on the heating function and bask in the warm air. The cute lights certainly don’t hurt, either.
    Project Arielle is just a concept for now, but Razer has a pretty good track record when it comes to turning its experiments into actual products. Just look at the Project Esther haptic gaming cushion, which debuted at CES 2024 and then went on sale nine months later as the Razer Freyja.
    Will Project Arielle help boost your rank or shave seconds off your speedrun? Maybe, maybe not. But it’ll definitely keep you cozy while you try.
    This article originally appeared on Engadget at https://www.engadget.com/gaming/pro...ontrolled-gaming-chair-140053304.html?src=rss
