  • " /> News - Samsung’s Pro Plus 512GB microSD card is a hefty 47% off right now | SoftoolStore.de - Программное обеспечение, Avid Media Composer, Книги, Новости, Windows, Интернет-новости, Бесплатные прокси (HTTP, Socks 4, Socks 5)
    News Samsung’s Pro Plus 512GB microSD card is a hefty 47% off right now
    If you’re in need of a decently sized microSD card at a great price, today’s your lucky day. The high-quality 512GB Samsung Pro Plus microSD card is now just $40 on Amazon, or a whopping 47 percent off its usual $76. That’s a crazy good price for half a terabyte!
    This microSD card goes well with your phone, tablet, gaming console, drone, GoPro, and basically anything else that accepts microSDs. With read speeds up to 180MB/s and write speeds up to 130MB/s, it’s fast enough to handle shooting 4K videos without dropping frames. Only care about transferring files? No worries. It’ll move data in a flash.
    It’s a durable card, too, able to withstand dips in water, extreme temperatures, and physical drops. And as a bonus, this thing comes with an SD adapter that lets you also use it in place of an SD card. That’s great for DSLR cameras, handheld consoles, and other larger devices.
    Get the 512GB version for just $40 (was $76)! If you don’t need that much space, consider the 128GB version for $20 (was $26). Or if you need more space, get the 1TB version for $100 (was $120). But value-wise, the 512GB is definitely the best bang for your buck!
    This reliable 512GB Samsung microSD is a bargain for $40
    Buy now at Amazon
