If you’re looking for an eco-friendly power solution for your summer adventures, we found a great discount just for you. The EcoFlow Delta 2 Portable Power Station, paired with two 100W solar panels, is now available for just $819, down from $1,299.
The EcoFlow Delta 2 boasts a 1024Wh capacity and delivers an 1800W output (with a surge of up to 2700W), making it perfect for outdoor enthusiasts. Whether camping, traveling in an RV, or enjoying a weekend getaway, this portable power station can charge up to 15 devices simultaneously.
With its remarkable solar efficiency, boasting a 23 percent conversion rate, the Delta 2 allows you to recharge the unit in just 5.1 hours using the two included solar panels. Simply place them in the sun and you’ll have a full battery by the time you’re done with your daily trail through the forest, making your outdoor adventures more convenient.
Investing in the Delta 2 is a smart choice, as it features LFP batteries with a life cycle of about 3,000 charges. This means you can rely on its service for years, making it a durable and cost-effective power solution for your outdoor activities.
One of the coolest things about the Delta 2 is its ability to power nearly any appliance. With an output comparable to traditional outdoor generators, this solar-powered generator can easily handle 90 percent of your appliances, including a small fridge or some cooking gear.
The trips you have planned off the beaten path this summer will definitely take on new dimensions when you bring the EcoFlow Delta 2 portable power station. Before adding this one to the cart, remember to use the $480 coupon on the front page to get the best price.
Save $480 on a Delta 2 portable power station and two solar panels at Amazon
Power
Power
