I don’t know about you, but I have areas in my house where Wi-Fi just poofs out of existence. These Wi-Fi dead zones can be really annoying and they aren’t always easy to fix.
If you have Wi-Fi dead zones that can’t be fixed, the TP-Link Deco AX3000 mesh system is down to $170 right now on Amazon—down from its original $280—and it might just be the solution you need.
The TP-Link Deco AX3000 is a mesh Wi-Fi system (also known as whole home Wi-Fi) that eliminates weak Wi-Fi signals and provides coverage of up to 6,500 square feet, which is likely far more than you actually need.
Mesh Wi-Fi performs better than traditional Wi-Fi boosters and range extenders at fixing dead zones. The end result? More stable Wi-Fi internet connections in every area of your home.
This one comes with three units that you arrange around your home. It can connect up to 150 devices simultaneously, which is ideal if you have a smart home with tons of smart lights, sensors, appliances, etc.
Setup and management are straightforward through the Deco app, making it easy to control your network. And since it comes with Alexa compatibility, you can even issue voice commands for things like turning off the guest Wi-Fi network.
Upgrading from a Wi-Fi router to a full-featured mesh Wi-Fi network is one of the best things you can do if you have Wi-Fi connectivity issues and difficulty getting a good signal in certain places. Grab this 3-pack of TP-Link Deco AX3000 units on sale right now to see for yourself!
Save $110 and say goodbye to Wi-Fi troubles
Buy now on Amazon
Buy now on Amazon
