The Ring Battery Doorbell Pro is a great video doorbell if you’re embedded in Amazon’s ecosystem and is currently $80 off. | Photo by Jennifer Pattison Tuohy / The Verge
If you’re looking for a way to protect yourself from porch pirates, it’s a good idea to invest in a solid smart video doorbell. The Ring Battery Doorbell Pro is one of the best on the market, and is available at an all-time low price of $149.99 ($80 off) at Woot until February 1st at 12:59AM ET.
The snappy battery-powered video doorbell is packed with a number of features that provide peace of mind. Its high-resolution 1536p video features a square aspect ratio, which is helpful as it allows you to get a complete view of your entire porch. The doorbell also supports motion detection using three sensors — radar, video analysis, and passive — for an impressive level of accuracy. Other standout features include good color night vision, dual-band Wi-Fi, and smart responses so you can talk to your visitor. The doorbell also integrates well with Amazon devices, allowing you to do things like pull up a live feed of your front door on an Echo Show or Fire TV-enabled television.
The downside is some features are paywalled. So if you want smart alerts for people and packages or recorded footage, you’ll have to fork out at least $4.99 a month (or $49.99 a year) for a subscription. But if you don’t mind that, the Ring Battery Doorbell Pro is an excellent video doorbell that’s particularly ideal for those embedded in Amazon’s ecosystem.
A couple more deals and discounts
- You can buy the Vornado MVH Whole Room Heater for $49.99 ($10 off) at Amazon, which is just $2 shy of its all-time low price. The portable heater is easy to use and does a good job of quietly and evenly warming up medium-sized rooms. It also offers three heart settings so you can dial in your ideal temperature and automatically shuts off when it reaches the set temperature.
- The 45mm, GPS-enabled Apple Watch Series 9 is down to an all-time low price of $279 ($50 off) at Walmart. The Series 9 lacks the Series 10’s Apple wide-angle OLED display and doesn’t offer built-in water temperature and depth sensors, but is otherwise similar. Like its successor, it sports Apple’s second-gen ultra wideband chip and the speedy S9 SiP, which allows for onboard Siri processing and the double tap gesture. It also supports watchOS 11 so you can take advantage of the new Training Load feature and pause your Activity Rings. Read our review.
- The Anker 511 charging adapter is on sale for $12.99 ($10 off) at Amazon and Anker when you apply the code WS7DV2M1LIOU, which matches its all-time low price. The USB-C charger can deliver 30-watts of power to smartphones, tablets, consoles, and other electronics and is small with a collapsible plug, making it travel-friendly.
