If your devices aren’t charging fast enough, it might be due to the wall plug (also known as a power adapter) you’re using. Getting ultra-fast charge times could be as simple as upgrading yours to this 100W Anker Prime wall plug that’s now on sale for $55 on Amazon.
This Anker Prime GaN charger features three ports: two USB-C and a USB-A. The USB-C ports can hit 100W when used solo, while the USB-A maxes out at 22.5W alone. (With multiple ports in use, the 100W total output gets split up. For example, with all three plugged in, it can deliver 46W + 30W + 22.5W, respectively.) You can connect your laptop, phone, and earbuds to keep them all charged in a jiffy.
And with this wall charger using GaN technology, it’s way smaller than your usual power adapter and generates less heat. That makes it great for travel in conjunction with its foldable prongs, protecting it from breakage and preventing it from scratching your other valuables. You can tuck this away in any bag and not worry about it at all.
Get your own Anker Prime 100W wall charger for $55 on Amazon while you can! It’s a fantastic price for an ultra-fast 3-device power adapter. And don’t forget about Amazon’s Spring Sale coming up! There are already lots of great early deals worth jumping on.
Save 37% on Anker's tiny yet powerful wall charger
Buy now at Amazon
Buy now at Amazon
