News Best October Prime Day deals on battery chargers & power banks: Last chance!
I've found the best October Prime Day 2025 deals on battery chargers and power banks, from small and portable battery packs to high-capacity chargers.
Image: Rob Schultz/Foundry
Amazon’s October Prime Big Deal Days 2025 sales event is almost over, but there are still some excellent deals to be found on chargers and power banks. This year’s event runs October 7-8 and whether you’re looking to snag a travel-friendly pocket charger or upgrade to a high-capacity drive, there is no better time to get discounted chargers and power banks.
You’ll need to be a Prime member to take advantage of Amazon’s steep discounts. If you aren’t a member already, check out our guide for how to get Amazon Prime for free.
As a tech editor, I’ve been following and writing about the latest tech deals professionally for years, and have developed a keen eye for finding the best sales from all over the internet. My picks take into account a combination of online reviews from tech sites like PCWorld (when available), user feedback, and pricing history. Read on for all of the best deals on chargers and power banks, and be sure to check out our Amazon October Prime Day Tech Deals 2025 hub for more great sales across all the tech categories.
Best October Prime Day 2025 deals on chargers & power banks
This Prime Day 2025 deal are hot. The Anker MagGo wireless charger for $25 off on Amazon is a personal favorite thanks to its charging stand as well as its Magsafe charging compatibility for convenient on-the-go charging.
If you need something rugged and reliable that you can bring on even the harshest of adventures, then look no further than the Blavor Solar Charger Power Bank on sale for $13 off on Amazon. This absolute tank of a power bank can recharge without the need for an outlet thanks to its built-in solar panel, and its IPX5 waterproof rating.
Other great October Prime Day deals
These aren’t the only Prime Day deals being tracked by the PCWorld team. If you’re looking to supercharge your home setup with the juiciest tech sales, hit the links for only the best expert-curated picks we’ve found.
FAQ
1.
What should I look for in a portable charger and power bank?
Quality can differ greatly among power banks, so it’s best to stick to recognizable brands like Anker, Mophie, Belkin, and the like. That said, there are a few things you should always look for when shopping for a power bank.
First, make sure the battery pack is Quick Charge 2.0, 3.0, or PD certified. Next, don’t put too much confidence in a company’s claims that it can charge certain devices in a specific amount of time, such as the pack can charge an iPhone 15 in two hours. Focus more on the battery capacity, along with weight and size. Larger capacities in the 20,000 mAh or higher range should be enough for most small devices such as tablets or smartphones. Finally, make sure that the power bank comes with all of the correct connectivity options you need—USB-A or USB-C, etc.
2.
What battery capacity should I look for in a charger?
For a portable power bank that you can easily travel with, you should look for a minimum of 10,000 mAh. Most models these days even offer 20,000 mAh for reasonable prices. The more mAh, the better. Just be sure to weigh your capacity needs against the physical size of the power bank.
Generally, the more mAh a power bank has, the larger its physical size and the heavier it is, as well. Therefore, we recommend when looking at a power bank, you first consider the amount of power you need to charge your devices, and then adjust your expectations according to the size and weight you are willing to carry around with you.
3.
What is mAh capacity?
The mAh (milliampere per hour) capacity rating refers to the available storage capacity for a battery. A higher number means that the battery can store more energy and has a longer battery life when charging a device. So for example, an iPhone 13 Pro Max’s battery is rated at 4,352 mAh. This means that a power bank with 10,000 mAh can fully recharge that phone a little over twice before running out of power.
Author: Sam Singleton, Assistant Editor, PCWorld
Sam Singleton is PCWorld's VPN beat reporter and jack of all trades. When he's not on the hunt for the best computer deals he's covering VPNs, productivity software, laptops, and a wide gamut of consumer-grade hardware and software.
Recent stories by Sam Singleton:
