We love a good sale, so we’re stoked to see some great USB flash drive deals on Prime Day 2024. Look no further for the best thumb drive discounts from all the big names in flash memory!
I’ve even curated these drives by capacity levels, so you can get exactly the right model for your specific needs. Whether you need a thumb drive to store your summer pics or want a larger flash drive to move 4K movies from your computer to the TV, we have you covered.
I’ve been a journalist for 18 years, focusing on consumer tech for 12 of them. I’ve spent a good chunk of this time looking for PC storage deals because they’re just so versatile and everyone needs a flash drive. To build the list below, I’ve taken into consideration multiple factors, from the manufacturer’s reputation to user reviews, and from extra features to the product’s pricing history.
If you want more cool tech discounts, you should check out our Prime Day 2024 deals hub.
First published on July 12, 2024. Last updated on July 16, 2024.
Prime Day 2024 deals on 64GB to 256GB USB flash drives
All these are amazing deals given the discounts, and you’d do well with any of them in your pocket. If you want the most storage space for the best price, go for the Kingston DataTraveler, especially since it supports read speeds of up to 200MB/s. I also really like the Samsung Fit Plus because it’s USB 3.1 with read speeds of up to 300MB/s, and it’s rather affordable.
Prime Day 2024 deals on 512GB to 2TB USB thumb drives
These are some awesome discounts across large storage flash drives! If you want the best price for the most storage, then getting the Move Speed YID makes perfect sense. If you’d rather go for a smaller capacity but faster read/write speeds, you may want to go for the Kingston DataTraveler Max.
While the SanDisk Extreme Pro discount looks great on paper, the top price we’ve actually seen in the past year has been $170. So while the discount is still impressive, and we’d buy this drive ourselves, it’s not as large as Amazon wants us to think.
Need more Prime Day recommendations? We’re here to help
My PCWorld colleagues have been scouring all of Amazon for the very best deals across all the main tech categories. Check out the discounts!
1.
How do I know a Prime Day deal on USB flash drives is good?
To figure out whether a Prime Day deal on thumb drives is good or not, you should compare the discounted price to the regular retail price. You should also check out the product’s reviews for opinions on reliability and quality. Of course, you could also check out the price history for the flash drive you want, as there are multiple platforms available online. Don’t worry, though, because we did that for you!
2.
What capacity do I need in a USB flash drive?
Figuring out what capacity you need in a USB flash drive depends on what you’ll use it for. If you’re going to store basic documents and small files, you can “get away” with buying a 64GB version. If you plan on storing pictures, video, or software, you can go up to 512GB, just so you don’t have to worry about it anytime soon.
Should you need to transfer large datasets, video projects or media libraries, the larger storage option, the better.
3.
What features should I look for in a USB flash drive?
When looking for a thumb drive, you need to consider what capacity you need, as well as what you’ll use it for. You should also look for USB 3.0 and above for faster read/write speeds.
Another thing your new flash drive should have is durability, so look for what materials they are made of, as aluminum casings will provide robust protection against bumps and drops.
If you’re going to use the flash drive to move sensitive files around, you may also want to look into getting one that offers encryption. Some thumb drives will offer 128-bit AES encryption, while others will offer 256-bit. Drives that offer the 256-bit encryption options are better protected, as the key can be more complicated, but 128-bit encryption will do just fine as well. Both encryption standards are considered to be practically impossible to crack.
Computer Storage Devices
- PNY Turbo Attache 3 2-pack, 256GB – $30 (Save $8)
- Lexar E32C, 128GB – $16 (Save $4)
- Samsung Fit Plus, 64GB – $14 (Save $11)
- SanDisk Ultra, 128GB, 128-bit AES encryption – $12 (Save $8)
- HP X900w, 128GB – $9 (Save $4)
- SanDisk 256GB iXpand Flash Drive Luxe, password protection – $59.95 (Save $30.04)
- Kingston DataTraveler 80 M, 256GB – $21.65 (save $5.34)
- Lexar 512GB JumpDrive P30 – $55 (Save $35)
- Samsung BAR Plus, 512GB – $65 (Save $15)
- SanDisk Ultra Fit, 512GB, 128-bit AES encryption – $33 (Save $57)
- Kingston DataTraveler Max, 1TB – $85.27 (Save $34.72)
- SanDisk Extreme PRO, 1TB, 128-bit AES encryption – $87.99 (Save $192)
- ADATA Elite UE800, 1TB – $70 (Save $30)
- Move Speed YID, 2TB – $148 (Save $52)
- Best Amazon tech deals across PCWorld’s top categories
- PC computer deals: Best of Prime Day 2024
- Laptop deals: Best of Prime Day 2024
- Monitor deals: Best of Prime Day 2024
- SSD and storage deals: Best of Prime Day 2024
- Thunderbolt dock and USB-C hub deals: Best of Prime Day 2024
- Office chairs and standing desks: Best of Prime Day 2024
- PC keyboard deals: Best of Prime Day 2024
- Battery charger deals: Best of Prime Day 2024
- Laptop bag and backpack deals: Best of Prime Day 2024
- Chromebook deals: Best of Prime Day 2024
- iPad, Galaxy Tab and Kindle deals: Best of Prime Day 2024
1.
2.
3.
