  • " /> News - CES 2023: IOGEAR Introduces USB-C Docking Solutions and Matrix KVM | SoftoolStore.de - Софт, Avid Media Composer, Книги. | бесплатные прокси (HTTP, Socks 4, Socks 5)
    News CES 2023: IOGEAR Introduces USB-C Docking Solutions and Matrix KVM
    IOGEAR has been servicing the computer accessories market with docks and KVMs for more than a couple of decades now. In addition to the generic use-cases, the company creates products that target niche segments with feature sets that are not available in products from other vendors. At CES 2023, IOGEAR is taking the wraps off a number of USB-C docks slated to get introduced over the next couple of quarters.
    Docking Solutions
    The three new products in this category fall under two categories - the first two utilize Display Link chips along with traditional USB-C Alt Mode support, while the third one uses the Intel Goshen Ridge Thunderbolt controller for 8K support in addition to the usual array of ports found in regular Thunderbolt 4 / USB4 docks. The following table summarizes the essential aspects of the three new products.
    IOGEAR USB-C Docking Solutions @ CES 2023 (Dock Pro Series)​
    Model Name
    GUD3C4K2TAA
    GUD3CDHTAA
    GUD4C8K3
    Upstream Port
    USB 3.2 Gen 2 Type-C
    2x USB 3.2 Gen 2 Type-C (Dual Host Support)
    USB4 Type-C (40 Gbps)
    Audio
    1x 3.5mm Combo Audio Jack
    1x Mic In
    1x Speaker Out
    USB-A
    2x USB 3.2 Gen 1
    1x USB 3.2 Gen 1 (12W charging)
    2x USB 2.0
    2x USB 3.2 Gen 2
    2x USB 3.2 Gen 2
    1x USB 3.2 Gen 1
    USB-C
    1x USB 3.2 Gen 2
    1x USB 3.2 Gen 2
    1x USB 3.2 Gen 2
    2x USB4 (40Gbps with DP Alt Mode up to 8Kp30) downstream
    Networking
    1x GbE RJ-45
    1x GbE RJ-45
    1x 2.5 GbE RJ-45
    Card Reader
    1x SDXC UHS-II
    1x microSDXC UHS-II
    Display Outputs
    2x HDMI 2.0a
    2x Display Port 1.2a
    (All via DisplayLink Chipset)
    (Max. of 2x 4Kp60 Outputs)
    2x Display Port 1.2a (4Kp60) (via DisplayLink Chipset)
    1x HDMI 1.4a (4Kp30) (via DP Alt Mode)
    2x HDMI 2.1 (up to 8Kp30)
    2x Display Port 2.1 (up to 8Kp30)
    (All via DP Alt Mode)
    Host Power Delivery
    USB PD 3.0 (up to 100W)
    Up to 100W per host (total 200W)
    USB PD 3.0 (up to 96W)
    Power Supply
    External 150W @ 20V/7.5A
    External 230W
    Dimensions
    91mm x 70mm x 17mm
    219mm x 88mm x 32mm
    225mm x 85mm x 18mm
    Launch Date
    March 2023
    June 2023
    March 2023
    MSRP
    $250
    $300
    $300
    The Dock Pro Universal Dual View Docking Station is a premium DisplayLink-based dock capable of driving up to two 4Kp60 displays, with a choice of HDMI or DisplayPort for each.
    The dock also includes host power delivery support, and the distribution of ports is presented above.
    The Dock Pro Duo USB-C Docking Station is ostensibly a USB-C dock, but it incorporates features typically found in KVMs. It allows two systems to be simultaneously connected to the dock, and a push button in front to cycle between one of four display modes as show in the picture below.
    The push button configures one of the two hosts to the DisplayLink chain (that is behind the two DisplayPort outputs). All the peripheral ports are seen by the host connected to that chain. At the same time, the HDMI port is kept active using the Alt Mode display output from the other host. Hot keys are available to cycle through the display modes to enable easy multi-tasking. This is an innovative combination of docking and KVM that I haven't seen from other vendors yet.
    Finally, we have the flagship USB4 / Thunderbolt 4 dock - the Dock Pro USB4 8K Triple View. It incorporates all the bells and whistles one might want from a TB4 dock, including downstream USB4 ports and 8K support.
    Surprisingly, the pricing is quite reasonable at $300 - possibly kept that way by avoiding Thunderbolt certification. This product could appeal to a different audience compared to the Plugable TBT4-UDZ despite similar pricing, thanks to the availability of downstream ports. However, the product is slated to ship only towards the end of the quarter.
    KVM Solutions
    IOGEAR is also announcing the GCMS1922 2-port 4K Dual View DisplayPort Matrix KVMP with USB 3.0 Hub and Audio. Such KVMs with 4Kp60 support have typically been priced upwards of $500. This is no exception with a $530 MSRP. However, for this pricing, IOGEAR is incorporating a number of interesting features. The KVM can operate in either matrix or extension mode, with one computer driving both display outputs in the latter, and each host driving one display in the former. In the matrix mode, the KVM also supports crossover switching via movement of the mouse pointer (in addition to the regular physical button on the KVM and hotkeys). Audio mixing support (i.e, keeping the audio output of a 'disconnected' host also active) is available too, allowing the monitoring of notifications from both computers without having to switch sources.
    The KVM provides two USB 3.2 Gen 1 and two USB 2.0 Type-A ports for downstream peripherals in addition to separate audio jacks for the speaker and microphone. It must be noted that the display outputs are HDMI, while the inputs are DisplayPort. The KVM switch is slated to become available later this quarter.
    In addition to these upcoming products, IOGEAR is also demonstrating the KeyMander Nexus Gaming KVM and the MECHLITE NANO compact USB / wireless keyboard at the show. These products were introduced into the market last year.
    Gallery: CES 2023: IOGEAR Introduces USB-C Docking Solutions and Matrix KVM
