On Monday, Anthropic announced Claude 3.7 Sonnet, a new AI language model with a simulated reasoning (SR) capability called "extended thinking," allowing the system to work through problems step by step. The company also revealed Claude Code, a command line AI agent for developers currently available as a limited research preview.
Anthropic calls Claude 3.7 the first "hybrid reasoning model" on the market, giving users the option to choose between quick responses or extended, visible chain-of-thought processing similar to OpenAI's o1 and o3 series models, Google's Gemini 2.0 Flash Thinking, and DeepSeek's R1. When using Claude 3.7's API, developers can specify exactly how many tokens the model should use for thinking, up to its 128,000 token output limit.
The new model is available across all Claude subscription plans, and the extended thinking mode feature is available on all plans except the free tier. API pricing remains unchanged at $3 per million input tokens and $15 per million output tokens, with thinking tokens included in the output pricing since they are part of the context considered by the model.
Read full article
Comments
Read full article
Comments
