You don’t realize it until you’ve tried it, but it’s just so convenient to be able to check who’s outside your door — or be alerted when things happen outside — from the comfort of your couch or bed. For that, you need a capable video doorbell.
It’s not just a passing fad. It’s a matter of comfort and security. So if you don’t have one already, you should consider getting one soon… and now’s a good time because the Ring Battery Doorbell is down to $60 on Amazon, a lovely $40 discount off its usual $100 price.
This is the newest version of the Ring Battery Doorbell (released in 2024) that delivers significantly more vertical coverage with “head-to-toe video,” letting you see the area outside your door more fully. That’s handy whether you spot a threat or simply see a delivery coming.
Per the name, this model is battery-operated, so you don’t have to wire it up to anything. Don’t have an existing doorbell? No problem. Just install the mount using screws, then clip the device into the mount. You can pop it off with a special tool, charge it inside with a USB-C cable, then pop it back into the mount. Good to go for several months at a time.
The Ring Battery Doorbell has two-way audio to chat with visitors remotely, and you can check the video feed from your phone or from an Echo Show device on the same network.
Give yourself peace of mind and extra convenience with a hassle-free video doorbell. Grab the Ring Battery Doorbell on Amazon for $60 while this limited-time deal lasts!
Save 40% and keep a watchful eye over your door from your phone
Buy now at Amazon
Buy now at Amazon
