- Reactions
If you want to be ready for anything, your tech drawer needs to have a few things always on hand—like a small-but-fast flash drive that you can whip out whenever you need to move files between devices. I’m talking about something like this Samsung Bar Plus on Amazon! Act now to get 256GB of portable storage for a mere $22. That’s a whopping 45% off its original MSRP and a solid price for this much space.
The best part about the Samsung Bar Plus—apart from its price—is that it can transfer files at up to 400 MB/s speeds, which means you can move large videos, archives, and folders in seconds. It’s widely compatible with any modern device that supports USB-A, too.
This USB flash drive has a sleek design and a rugged metal casing that makes it more durable than most of its competitors. It’s waterproof, shockproof, and built to withstand extreme temperatures, damage from magnets, and even X-ray machines. You can carry this thing anywhere you go, and it has a convenient keyring hole for looping onto a lanyard.
While 256GB is the sweet spot for many, if you need more or less, know that the other capacities are also on sale: the 128GB model is $15 (was $23) and the 512GB model is $63 (was $80). But for the best bang for your buck, get the 256GB model for $22 (was $40)!
Save 45% on the Samsung Bar Plus USB flash drive
Buy now at Amazon
Buy now at Amazon
