- 15 Февраль 2018
I can be pretty frugal, but if there is anything I am perfectly fine overspending with, it is work equipment. A good monitor definitely changes the way you work, but in this case, it can also be an awesome entertainment gadget. The Samsung Smart Monitor M8 (M80D) can work as both a monitor and a TV replacement, and while it’s usually quite pricey, right now it is $300 off!
Buy the Samsung Smart Monitor M8 for just $399.99 ($300 off)
This offer is available straight from Amazon. As a “limited time deal,” it requires no Prime subscription or secondary steps. Simply add it to your cart and proceed to checkout to enjoy the savings.
I live alone, so my place is rather small. It’s very comfy in here, but I do have to worry about optimizing my reduced space, which is why I try to be careful about what I take home. Something like the Samsung Smart Monitor M8 (M80D) is ideal for anyone looking to save space. The issue is that it is usually expensive, with a retail price of $799. At $399.99, though, it is looking like a much more enticing option.
The Samsung Smart Monitor M8 sports a 32-inch panel. This isn’t huge by TV standards, but it is a pretty nice size for a smaller room. It helps that this size is considered pretty large in the world of monitors, so it strikes a nice in-between balance. You’ll get a sharp 4K resolution with HDR10+ support, which is great for both monitor and streaming purposes. You’ll also enjoy access to both HDMI and USB-C for video intake.
I am also a big fan of minimalist design, so it will look great when turned off as well. It comes with a remote, which you can use to control settings and navigate through Tizen, Samsung’s own smart TV platform. As if that wasn’t enough, you’ll even be able to play cloud games, thanks to access to the Samsung Gaming Hub.
As you can see, this isn’t your typical monitor, and this $300 discount is looking like a great opportunity. Go get yours before the price jumps back to normal.
