Image: Meta
Meta is releasing a charging dock for its new Quest 3 headset. For $129.99, the all-in-one charging station allows you to neatly mount and charge the Quest 3 headset and controllers when you’re not immersed in virtual reality.
This charging station is the first of its kind for Meta. While the company offered a charging dock for the Quest Pro 2, it was wired and didn’t provide a way to charge both the headset and controllers on a single platform (mainly because the controllers use AA batteries). This new dock is more similar to the two-in-one station Anker made for the Quest 2. It lets you charge the headset using the contact pads on the bottom of the Quest 3.
The controllers are a little trickier, as they likely continue to use AA...
Continue reading…
