- Reactions
Samsung really makes the most insane gaming monitors and we can’t get enough of them, especially when we spot them with steep discounts. The company’s massive 49-inch Odyssey OLED G9 is down $800 right now, which means you can get it for $1,000. That’s 48% off!
This is a monitor that delivers everything you could possibly want, whether you’re using it for work, fun, or gaming. Who could turn their nose down at the incredible 5120×1440 resolution? That’s basically two 1440p monitors smooshed together. And when it’s stretched across 49 glorious inches, the experience is as immersive as it gets.
What makes this monitor gaming-ready is the fast 240Hz refresh rate and 0.03ms response time. As long as your computer is powerful enough to keep up with that, you’ll be good to go—but do note that means you’ll need a properly powerful gaming rig of a PC. The Odyssey OLED G9 is also compatible with AMD FreeSync Premium Pro and Nvidia G-Sync.
The curved screen makes the huge screen easier on your eyes, by the way. You’ll be able to spend more hours gaming and working without eye strain. Not to mention the vivid OLED panel with its deep blacks, vibrant colors, and cutting-edge visuals.
What are you waiting for? Jump on this Samsung 49-inch OLED ultrawide for only $1,000 while this hot deal is still active!
Save $800 on Samsung's 49-inch ultrawide OLED gaming monitor
Buy now at Amazon
Buy now at Amazon
