Photo by Chris Welch / The Verge
The Sonos Ace headphones launched with a very convenient trick called TV Audio Swap, which lets you send audio that would normally come out of the Sonos Arc soundbar to the headphones instead. Two months later, the company is enabling TV Audio Swap on its more affordable soundbars — and it’s no longer limited to customers with Apple devices.
The feature now works on both generations of the Sonos Beam as well as the entry-level Sonos Ray. Until now, an iPhone or iPad was required to activate TV Audio Swap, but now Android devices can do so as well. The feature itself uses a direct Wi-Fi connection to send audio from the soundbar to the headphones, but you’ll need the app for setup and to toggle certain settings.
Photo by...
Continue reading…
