Among the packed field of PC hardware manufacturers, Lian Li is a company that arguably shouldn't even need an introduction. The quirky company has developed a devout following thanks to its focus on premium-quality aluminum computer cases that, more often that not, and come with in some rather unique designs. Over the years, the company has developed a solid reputation for its meticulous craftsmanship, durability, and elegant aesthetics. And consequently, when the company made the decision to expand beyond aluminum cases and in to other PC peripherals, that development attracted quite a bit of attention to see what kind of a touch Lian Li could bring to the rest of the PC ecosystem.
Lian Li's focus on premium products means that the company doesn't really make much in the way of products that are merely basic, and that kind of mentality has extended beyond cases and into the rest of their peripherals. Case in point is the subject of today's review: Lian Li's new all-in-one CPU cooler, the HydroShift LCD 360S AIO. Not content just to make a powerful 360 mm cooler, Lian Li has gone a step above by integrating recesses and other features to help hide the tubing around the cooler, and then for the coup de grace, added a high-quality 2.88-inch IPS display to the pump block.
Overall, this new product marks a significant milestone for Lian Li, as it combines advanced cooling technology with the company's signature aesthetic appeal, making for a cooler that's aimed at both enthusiasts and professional users seeking high-end thermal performance and visual customization. Overall, the HydroShift LCD 360S is undeniably designed first and foremost with aesthetics in mind, but the shiny pump block is backed up with one of the most powerful 360 mm cooler designs on the market today. So Lian Li is throwing everything they have at the new HydroShift coolers.
Overall, the 360S is part of a trio of HydroShift 360 mm coolers the company is launching this summer. All three share a similar design, although with some pump changes and the addition of RGB fan lighting, depending on the specific model, with the 360S effectively serving as the base model.
