  • " /> News - Mercedes-Benz finally unveils its electric G-Class luxury off-roader | SoftoolStore.de - Софт, Avid Media Composer, Книги. | бесплатные прокси (HTTP, Socks 4, Socks 5)
    News Mercedes-Benz finally unveils its electric G-Class luxury off-roader
    Back in 2022, Mercedes-Benz announced that it was going to release an electric G-Class by the end of 2024. Now, the automaker has formally introduced the electrified version of its iconic luxury vehicle that's known for its exclusivity. The Mercedes-Benz G 580 with EQ Technology comes equipped with a 116 kWh lithium-ion battery that gives it enough energy to run for up to 473 kilometers (294 miles) on a single charge. It also has a maximum total output of 432 kW and a maximum torque of 1,164 Nm.
    The electric model looks pretty much like the gas-powered G-Class, with its sharp angles and its distinctive door handles, grilles and round headlights. Mercedes offers optional lighting exclusive to the EQ version of the vehicle, though, so you can change its looks and give it a design that's considerably different from a standard G-Class. The vehicle is powered by four electric motors located near each wheel and has several modes for off-road use: G-TURN, which will allow you to turn the vehicle almost on the spot, G-STEERING, which could eliminate the need for multi-point turns, and the intelligent off-road crawl function that provides cruise control for off-road drives.
    Mercedes-Benz made sure the vehicle's battery is ready for off-road journeys, as well, and encased it in a torsion-resistant casing that protects it from water and dirt. Since the vehicle can be driven in up to 33.5 inches of water, the battery definitely needs that kind of protection. It can charge with both alternating current and direct current, and when plugged into a fast-charging DC system, it can go from 10 to 80 percent in just 32 minutes. The G-Class can convert kinetic energy into electrical energy when you coast or hit the brakes, as well.
    EDITION ONE, the G-Class with EQ Technology coming out at launch later this year, will have an "an expanded palette of standard features." A company spokesperson told TechCrunch that a range-extended version with a battery that uses a more energy-dense silicon-anode technology from Mercedes' partner Silas will also be available in the next few years.
    This article originally appeared on Engadget at https://www.engadget.com/mercedes-b...lass-luxury-off-roader-110040316.html?src=rss
