• Thread starter News
  • " /> News - NASA still doesn’t understand root cause of Orion heat shield issue | SoftoolStore.de - Софт, Avid Media Composer, Книги. | бесплатные прокси (HTTP, Socks 4, Socks 5)
    News NASA still doesn’t understand root cause of Orion heat shield issue
    Enlarge / NASA's Orion spacecraft descends toward the Pacific Ocean on December 11, 2021, at the end of the Artemis I mission. (credit: NASA)
    NASA officials declared the Artemis I mission successful in late 2021, and it's hard to argue with that assessment. The Space Launch System rocket and Orion spacecraft performed nearly flawlessly on an unpiloted flight that took it around the Moon and back to Earth, setting the stage for the Artemis II, the program's first crew mission.
    But one of the things engineers saw on Artemis I that didn't quite match expectations was an issue with the Orion spacecraft's heat shield. As the capsule streaked back into Earth's atmosphere at the end of the mission, the heat shield ablated, or burned off, in a different manner than predicted by computer models.
    More of the charred material than expected came off the heat shield during the Artemis I reentry, and the way it came off was somewhat uneven, NASA officials said. Orion's heat shield is made of a material called Avcoat, which is designed to burn off as the spacecraft plunges into the atmosphere at 25,000 mph (40,000 km per hour). Coming back from the Moon, Orion encountered temperatures up to 5,000° Fahrenheit (2,760° Celsius), hotter than a spacecraft sees when it reenters the atmosphere from low-Earth orbit.
    Read 14 remaining paragraphs | Comments
