• Thread starter News
  • " /> News - Beats announces Solo Buds, $80 wireless earbuds with 18-hour battery life | SoftoolStore.de - Софт, Avid Media Composer, Книги. | бесплатные прокси (HTTP, Socks 4, Socks 5)
    News Beats announces Solo Buds, $80 wireless earbuds with 18-hour battery life
    Beats has a solid track record when it comes to wireless earbuds. The company consistently offers good audio performance with a comfy fit and a nice list of features for both Android and iOS users. In fact, the Beats Fit Pro are our current top pick for best workout earbuds. The one thing the company doesn't have in its lineup is a budget-friendly option, but that will change soon. Today, Beats revealed the Solo Buds: an $80 set of wireless earbuds that offer 18 hours of use on a single charge. There are some caveats on the spec sheet, but you might be willing to overlook them for that battery life at that price.
    The Solo Buds have the longest battery life on a set of Beats earbuds ever. 18 hours is way more than you'll probably ever use in one go, but there's a catch. The Solo Buds case doesn't have a battery, so the earbuds won't top up when you're not using them. The case is essentially a dock and will only charge the buds when it's plugged in with a USB-C cable. You'll be able to charge it with your phone, laptop or tablet though, and Beats' Fast Fuel feature gives your an hour of use in five minutes. The upside to the non-charging case is that accessory is significantly smaller since it doesn't hold a battery.
    Beats has designed the Solo Buds to be worn for long periods of time. More specifically, ergonomic acoustic nozzles and vents assist with audio performance while relieving pressure. Four sizes of ear tips are included in the box so you can find the best option for your ears in terms of both comfort and passive noise isolation. There's no active noise cancellation (ANC) here, so a secure fit will be your only defense against environmental distractions.
    Inside, dual-layer transducers are designed to reduce distortion across the frequency curve which should lead to "uncompromising clarity and detail," according to Beats. The company describes call quality as "exceptional," thanks to the combination of a custom-designed mic and a noise-learning algorithm. Onboard controls are customizable, putting music, call and voice assistant functions a press or multiple presses away. Beats also includes the option for volume controls on the Solo Buds with an optional press-and-hold action.
    Native compatibility in Android and iOS delivers one-touch pairing, automatic setup and support for Find My and Find My Device. Everything you'll need on iPhone is built into iOS while Beats offers a standalone app on Android for things like onboard control customization.
    The Solo Buds will be available in June in black, gray, purple and transparent red color options for $80.
    This article originally appeared on Engadget at https://www.engadget.com/beats-anno...h-18-hour-battery-life-140054881.html?src=rss
