  • " /> News - How to uninstall McAfee antivirus | SoftoolStore.de - Софт, Avid Media Composer, Книги. | бесплатные прокси (HTTP, Socks 4, Socks 5)
    News How to uninstall McAfee antivirus
    A fresh PC usually feels shiny and exciting, except when it comes packed with extra software that you never asked for—like a trial of McAfee’s antivirus software. Inevitably, the evaluation period ends, and with it begins an onslaught of notifications asking you sign up for a paid subscription. Heck, sometimes the reminders begin long before the expiration date.
    If you’re tired of the harassment, or just want to get back to Windows’ more streamlined built-in protections, here’s how to uninstall McAfee antivirus.
    Looking for more options? Check out PCWorld’s roundup of the best antivirus software of 2024.
    Step 1: Open the Settings app
    To uninstall programs, first you must head to the Apps section within the Settings app.
    In Windows 10, hit the Start key on your keyboard, and then type apps. Select Apps & features.
    In Windows 11, hit the Start key on your keyboard,, then type installed apps. Choose Installed Apps.
    Step 2: Uninstall McAfee
    The McAfee app within Windows 10’s installed app list.
    PCWorld
    PCWorld
    PCWorld
    Scroll down the list of installed apps and find McAfee.
    In Windows 10, click on McAfee in the list, then on the Uninstall button.
    In Windows 11, click the three dot icon on the far right, then choose Uninstall.
    If a User Account Control permission window appears, click Yes to approve the request to make a chance on your PC. McAfee may then flash a pop-up asking for you to answer a survey (you can decline), as well as another for confirmation that you want to remove the software.
    After the uninstallation is complete, reboot your PC.
    check out pcworld's top pick for antivirus software
    Norton 360 Deluxe
    Read our review
    Price When Reviewed: 34,99 im ersten Jahr
    Best Prices Today: €34.99 at Norton
    Step 3: Repeat for other McAfee components
    Be sure to uninstall other associated McAfee software.
    PCWorld
    PCWorld
    PCWorld
    You may have more than just McAfee’s antivirus software on your system—if the trial was for a broader subscription that also included services like the company’s VPN and parental controls, you’ll need to uninstall those apps separately.
    Reboot your PC after uninstalling each component.
    Step 4: Confirm Windows Security is active
    On this PC, App & browser control should be turned on for fuller protection.
    PCWorld
    PCWorld
    PCWorld
    After the dust settles, open the Start menu, then type windows security and launch the app.
    Under Virus & threat protection, your status should say No action needed. If it says Unknown, reboot your PC and then look again. We recommend also turning on App & browser control if you see a prompt to do so (like in the screenshot above).
    After you’ve performed this step, you should be good to go—you can either let Windows continue doing its thing, or install different third-party antivirus software more to your liking.
    Antivirus
