Credit: Robert Triggs / Android Authority
Apple and Google are two brands that pride themself on best-in-class camera phones. They’ve built reputations on it and continue to play to this strength with the latest iPhone 15 Pro and Pixel 8 Pro. This begs the question: if you have $999 to spend on your next smartphone upgrade, what should an avid photographer buy?
Does the Pixel 8 Pro have a better camera than the iPhone 15 Pro?
Yes, but it depends on the situation. Here’s the TLDR from our article:
- The two phones have great primary cameras. The Pixel 8 Pro looks more muted and realistic, while Apple targets more contrast and color pop.
- The iPhone 15 Pro still has issues with yellow tints and occasional under-exposure.
- Google’s ultrawide camera fits more in, but Apple’s camera suffers from fewer lens distortion issues.
- Google’s Pixel 8 Pro takes better-looking pictures when using long-range zoom.
- Both phones take excellent selfies, but the iPhone 15 Pro is more consistent in tricky lighting.
- Overall, the Google Pixel 8 Pro is the most consistent camera across a wider range of scenarios, but the Apple iPhone 15 Pro still takes scintillating pictures most of the time.
Pixel 8 Pro vs iPhone 15 Pro camera specs
Before the pictures, a quick recap of what the Pixel 8 Pro and iPhone 15 Pro offer in their rear camera arrays. Both pack a high-resolution primary sensor, an ultrawide lens to fit more in, and a telephoto camera for longer-range snaps. It’s a tried and tested formula that offers plenty of versatility across shooting situations. However, peer into the specifics and there are some key differences worth highlighting.
