This smart lightbulb from Kasa requires no hub or special equipment to operate. Set timers, on/off schedules, and fully adjust the brightness from 1-100% using an app, or with your voice though Amazon Alexa or Google Assistant.
The list price on this bulb is $16.99, but right now on Amazon you can buy it for just $7.99, the lowest price in over a year. That’s a great deal if you’re looking to add some basic automation to the lights inside your home, or outside on a porch. The 53% discount is active on Amazon right now (see it here), where the bulb gets 4.5 out of 5 stars from nearly 15,000 reviewers. If you’re looking for multiple bulbs, you’ll want to consider the 4-pack (you can find that right here) which is currently 41% off ($26.67) and drops the price per bulb down even lower to just $6.67.
Smart Home
Smart Home
